19/11/07 09:12:35 INFO Worker: Started daemon with process name: 11@2012a7e7fa5c
19/11/07 09:12:35 INFO SignalUtils: Registered signal handler for TERM
19/11/07 09:12:35 INFO SignalUtils: Registered signal handler for HUP
19/11/07 09:12:35 INFO SignalUtils: Registered signal handler for INT
19/11/07 09:12:35 WARN NativeCodeLoader: Unable to load native-hadoop library for your platform… using builtin-java classes where applicable
19/11/07 09:12:35 INFO SecurityManager: Changing view acls to: root
19/11/07 09:12:35 INFO SecurityManager: Changing modify acls to: root
19/11/07 09:12:35 INFO SecurityManager: Changing view acls groups to:
19/11/07 09:12:35 INFO SecurityManager: Changing modify acls groups to:
19/11/07 09:12:36 INFO SecurityManager: SecurityManager: authentication disabled; ui acls disabled; users with view permissions: Set(root); groups with view permissions: Set(); users with modify permissions: Set(root); groups with modify permissions: Set()
19/11/07 09:12:36 INFO Utils: Successfully started service ‘sparkWorker’ on port 35039.
19/11/07 09:12:36 INFO Worker: Starting Spark worker 172.18.0.14:35039 with 2 cores, 1024.0 MB RAM
19/11/07 09:12:36 INFO Worker: Running Spark version 2.4.3
19/11/07 09:12:36 INFO Worker: Spark home: /opt/spark
19/11/07 09:12:37 INFO Utils: Successfully started service ‘WorkerUI’ on port 38081.
19/11/07 09:12:37 INFO WorkerWebUI: Bound WorkerWebUI to 0.0.0.0, and started at http://2012a7e7fa5c:38081
19/11/07 09:12:37 INFO Worker: Connecting to master tispark-master:7077…
19/11/07 09:12:37 INFO TransportClientFactory: Successfully created connection to tispark-master/172.18.0.12:7077 after 67 ms (0 ms spent in bootstraps)
19/11/07 09:12:37 INFO Worker: Successfully registered with master spark://0.0.0.0:7077
19/11/07 09:12:35 INFO Master: Started daemon with process name: 11@9d9b5b578a76
19/11/07 09:12:36 INFO Utils: Successfully started service ‘sparkMaster’ on port 7077.
19/11/07 09:12:36 INFO Master: Starting Spark master at spark://0.0.0.0:7077
19/11/07 09:12:36 INFO Master: Running Spark version 2.4.3
19/11/07 09:12:36 INFO Utils: Successfully started service ‘MasterUI’ on port 8080.
19/11/07 09:12:37 INFO MasterWebUI: Bound MasterWebUI to 0.0.0.0, and started at http://9d9b5b578a76:8080
19/11/07 09:12:37 INFO Master: I have been elected leader! New state: ALIVE
19/11/07 09:12:37 INFO Master: Registering worker 172.18.0.14:35039 with 2 cores, 1024.0 MB RAM
tidb-docker-compose_grafana_1
t=2019-11-07T09:12:33+0000 lvl=eror msg=“Can’t read alert notification provisioning files from directory” logger=provisioning.notifiers path=/etc/grafana/provisioning/notifiers error=“open /etc/grafana/provisioning/notifiers: no such file or directory”
t=2019-11-07T09:17:50+0000 lvl=eror msg=“Dashboard not found” logger=context userId=0 orgId=1 uname= error=“Dashboard not found”
