为提高效率,提问时请提供以下信息,问题描述清晰可优先响应。
- 【TiDB 版本】: 5.7.25-TiDB-v2.1.17
脚本输出集群信息:
系统信息
| Host | Release |
| tikv1 | 3.10.0-514.el7.x86_64 |
| tikv2 | 3.10.0-514.el7.x86_64 |
| tikv3 | 3.10.0-514.el7.x86_64 |
TiDB 集群信息
| TiDB_version | Clu_replicas | TiDB | PD | TiKV |
| 5.7.25-TiDB-v2.1.17 | 3 | 2 | 3 | 3 |
集群节点信息
| Node_IP | Server_info |
| instance_0 | tikv+pd |
| instance_1 | pd+tikv+tidb |
| instance_2 | tikv+pd+tidb |
容量 & region 数量
| Storage_capacity_GB | Storage_uesd_GB | Region_count |
| 2598.73 | 67.14 | 1902 |
QPS
| Clu_QPS | Duration_99_MS | Duration_999_MS |
| 1638.84 | 1574.65 | 3838.43 |
热点 region 信息
| Store | Hot_read | Hot_write |
| store-store_5 | 1 | 3 |
| store-store_4 | 0 | 3 |
| store-store_1 | 0 | 2 |
磁盘延迟信息
| Device | Instance | Read_lat_MS | Write_lat_MS |
- 【问题描述】:
1.安装前提:使用ansible安装时跳过了磁盘IO的检测,因为没使用ssd。 安装时检测的磁盘IPOS如下:
- 在写入数据的时,通过iostat 发现%util持续90%以上,而CPU资源非常宽裕(32核)
根据官方文档Tikv性能调优文章中介绍的几个关键配置修改自己的tikv配置如下(对level0和level1层的数据压缩),io依然是瓶颈,cpu资源占用也还是很少,请问配置应该如何调整还是有其他问题?
tikv配置:
[server]
grpc-concurrency = 8
grpc-raft-conn-num = 24
labels = { }
[storage]
scheduler-worker-pool-size = 28
[pd]
This section will be overwritten by command line parameters
[metric]
address = “10.0.60.107:9091”
interval = “15s”
job = “tikv”
[raftstore]
raftdb-path = “”
region-split-check-diff = “32MB”
sync-log = true
[coprocessor]
region-max-size = “384MB”
region-split-size = “256MB”
[rocksdb]
max-background-jobs = 28
wal-dir = “”
[rocksdb.defaultcf]
block-cache-size = “15GB”
compression-per-level = [“zlib”, “zlib”, “lz4”, “lz4”, “lz4”, “zstd”, “zstd”]
max-bytes-for-level-base = “128MB”
target-file-size-base = “32MB”
[rocksdb.lockcf]
[rocksdb.writecf]
block-cache-size = “9GB”
[raftdb]
[raftdb.defaultcf]
block-cache-size = “2GB”
