error: failed to run custom build command for `snappy-sys v0.1.0 (https://github.com/busyjay/rust-snappy.git?branch=static-link#8c12738b)`
Caused by:
process didn't exit successfully: `/usr/local/denali-tidb/tikv/target/debug/build/snappy-sys-767f8d823b86bde4/build-script-build` (exit code: 101)
--- stdout
running: "cmake" "/root/.cargo/git/checkouts/rust-snappy-0ed33e4b7b96fc57/8c12738/snappy-sys/snappy" "-DCMAKE_INSTALL_PREFIX=/usr/local/denali-tidb/tikv/target/debug/build/snappy-sys-4e3bffdbe48b66eb/out" "-DCMAKE_C_FLAGS= -ffunction-sections -fdata-sections -fPIC" "-DCMAKE_C_COMPILER=/usr/bin/cc" "-DCMAKE_CXX_FLAGS= -ffunction-sections -fdata-sections -fPIC" "-DCMAKE_CXX_COMPILER=/usr/bin/c++" "-DCMAKE_BUILD_TYPE=Debug"
--- stderr
thread 'main' panicked at '
failed to execute command: No such file or directory (os error 2)
is `cmake` not installed?
build script failed, must exit now', /root/.cargo/registry/src/mirrors.ustc.edu.cn-61ef6e0cd06fb9b8/cmake-0.1.35/src/lib.rs:778:5
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace.
warning: build failed, waiting for other jobs to finish...
error: build failed
